Hey Juliette, a CUBE would be cool as!
Indeed. I've wanted one for the last two years. Instead of continually obsessing over them I'm going to buy one.
YES!
Oh yeah :)
try this Juliette. its a rebadged scion i think linky
Negatory. They're overpriced and have no personality whatsoever. My Cube will cost half that (and much less to run.)
looked into buying a cube. just quietly... it kinda sucked for daily driving (borrowed a mate's one for a week).
great if you wanna stand out. horrible blind spots, bad fuel economy, kept feeling like I was driving a van and if I crashed I was gonna get flung through the window.
so I bought a golf instead :huh: 7L/100km on 95 octane. diesel does 5L/100km. cbf with diesel though, accelerates like a snail. at least the 2L petrol accelerates like a turtle.
It'll be better than what I daily drive now as far as comfort and fuel economy go. It'll also be more practical and easier to park. I'm honestly just madly in love with them. Can't wait until Ben (J-spec) or I track down exactly the example I'm chasing. It could be a few weeks before exactly what I want pops up, but I'm sure it will. There's thousands upon thousands for sale.
postman pat
how would you reference engine efficiency as an equation?
and what about things like turbo linear flow vs rpm etc
like
POWER = STD POWER x (TURBO x INTAKE x EXHAUST x TUNE)
ie in its most simplistic form
so say INTAKE is 1.0 for std bog stock and say a pod filter is 1.03 and pod filter with ducting and shield is 1.04
how woudl you factor in a std turbo which is linear , vs say a T88 which is non-linear and insta-wheelspine when efficient?
say std turbo TURBO is 1.0 and T88 it is 2.25 but that would just magically shift the power up, which isnt right, so how do u linear bend the curve ? (in mathematics)
Thanks, but I've already paid J-spec their broker fee.
I'm also after one pretty specifically so I'm waiting for one that suits my criteria to come up.
ah yeh haha
yeah this guy has one forsale but is an importer, so couldve got what you were looking for to
but better to not waste the broker fee :whistling:
postman pat
like
haha that shit sounds wack!
engine power is proportional to density, fuel, pressure, rpm, etc
Im thinking you would probably need to come up with a formula for a given curve on a compressor map which fits the turbo (based on the amount of boost you choosing to run);
http://en.wikipedia.org/wiki/Compressor_map
http://www.turbocharged.com/catalog/compmaps/fig9.html
Then work out roughly how much a psi of boost would increase in horsepower or something. Never covered engine design etc in my stream of engineering.
My friends are in their final year of aerospace engineering and have crunched some epic numbers for jet engines etc, ill run the question past them and see if they got any ideas.
Shan - search function on J-spec is shizen, especially when I'm spending at least 4 hours a day on there at the moment :P
You should tell craig about it... like exact details and why. He's been tryin to make it better for users. [email protected]
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
