I dunno what it is, but Cadbury milk choc gives me a very slight allergic reaction. Nestle, lindt etc are all fine, just cadbury, and only their milk choc, their white, mixed and dark is fine.
learn to read nga.
Nga wat!
LOL!
anyone got rc drift cars here? they are friggin sweet.
Hell yeah, Tamiya TT-01, S15, 240Z and RX7 FD shells, TE37's +3 and +6 Offsets. (Offset + and - are opposite to real wheels)
I really should get back into it.
yeh i just bought one last week fkn awesome fun. got r32 gtr shell led headlights/taillights tt01 as well.
need more offset got +2 but to sunken haha
+2?
Dude, my +3's are sunk as fuck! :D
Go +6 to fill out or +9 for Poke.
TE37's and WORK Meister S1 are sic with the deep lip, which I have.
nah need to go lower offset to stick out higher offset will sit in.. i need +/- 0 or there arbouts i thinks
:P you talking about RC car or real car..?
:D
+/- 0 = Stock, no deep lip nothing
post pics of ya cars dood
NEEDS MORE LOW!
Cuz I have to trim the body shell so it does not scrap the ground.
TE37 +6 Offset.
Still needs more low, trimming still needed on body shell
WORK Meister +6 Offset.
EPIC RX7 FD!
Epic poke and it is just the stock Tamiya RX7 FD Body Shell. (SAU Member AE92's car)
http://www.skylinesaustralia.com/forums/R3...l&hl=rc+car = Check out the tread.
    • Started sifting thru my brakes to decide which ones I will run on Clem   Made me think I should just put them all on Silver...for when brake fade just isn't an option   Should be able to bump rotor up from 343x32 to 348x36 off Supra. Not sure if the Supra annulus is right for the Alcons or APs but trying g to find a used Supra\M4 rotor to test fit The Alcons seem to gain 1-2mm clearance which all helps
    • So car is getting a few mods to the cage and some jacking points welded in Meantime Ol Silver gets a new gearbox and shiny clutch.  Old Box is being set aside for Clem
    • Probably speedometer itself if the odometer is ticking. If the needle is stuck from a bit of grease or something that can cause it to stay at 0. Or a cracked solder joint in the speedometer can do it too.
    • Thanks Fella’s   to take this off topic and to elaborate a bit more. I have an rb25/30 going into a r32 GTST.. expected to make around 600-700hp. Would you?   A) R34 GTT box   B) CD00#?  I’ve seen a few posts about the CD swap and sounds fairly involved with making it fit etc but if it’s worth the work then I’ll go that way
    • Lower at the hubs. Funny I forgot to mention that part. Do this pull here I turned the camera off too soon but the graph shows a drop at the top and that was because the pipe from the turbo blew off. The tuner said we could’ve made possibly another 15 whp. He also added if I switched to ethanol we could up the boost some more as well. I was comfortable capping it at the most of 20 pounds. Turns out the turbo pipe just needed a new worm clamp. Got home replaced that then did a third gear pull from 3k to 7200 rpm and the power was great to the top. I just got an ecu mounting bracket from IEE that I need to try and get everything to fit well. It’s a PITA to get the harness and ecu fit properly behind that kick plate
