I dunno what it is, but Cadbury milk choc gives me a very slight allergic reaction. Nestle, lindt etc are all fine, just cadbury, and only their milk choc, their white, mixed and dark is fine.
learn to read nga.
Nga wat!
LOL!
anyone got rc drift cars here? they are friggin sweet.
Hell yeah, Tamiya TT-01, S15, 240Z and RX7 FD shells, TE37's +3 and +6 Offsets. (Offset + and - are opposite to real wheels)
I really should get back into it.
yeh i just bought one last week fkn awesome fun. got r32 gtr shell led headlights/taillights tt01 as well.
need more offset got +2 but to sunken haha
+2?
Dude, my +3's are sunk as fuck! :D
Go +6 to fill out or +9 for Poke.
TE37's and WORK Meister S1 are sic with the deep lip, which I have.
nah need to go lower offset to stick out higher offset will sit in.. i need +/- 0 or there arbouts i thinks
:P you talking about RC car or real car..?
:D
+/- 0 = Stock, no deep lip nothing
post pics of ya cars dood
NEEDS MORE LOW!
Cuz I have to trim the body shell so it does not scrap the ground.
TE37 +6 Offset.
Still needs more low, trimming still needed on body shell
WORK Meister +6 Offset.
EPIC RX7 FD!
Epic poke and it is just the stock Tamiya RX7 FD Body Shell. (SAU Member AE92's car)
http://www.skylinesaustralia.com/forums/R3...l&hl=rc+car = Check out the tread.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
