I haven't had the other 2 for agessss man :P
But yeah, Supra was meant to be gone today but the dead battery screwed me around.
MR2 should be 100% functional pretty soon :D Then I'll come on a cruise or even organise something myself.
Yeah cool!
Get your MR2 on!
I know another N/A R33 here that made 96rwkw from memory :P I won't name names though.
Was yours modified Leigh?
There's a few guys on Supra forums with 155rwkw or more. Pretty good effort for an N/A I reckon :D
even tho you may have an extra 10kw/tonne, the weight will be far more noticeable when turning, stopping and controlling in an oversteer... you know... those functions of your car that don't involve raw power.
put it this way, get the tail end out to 45 degrees in a poopra, a 300zx and a skyline, and see which one is easier to catch and bring back into line.
hey scott, where did your mate get the 5th season of its always sunny in philly?
cant find it on ebay anywhere
finally internets back, had to go through and see whats going on in the wasteland and i can see not much lol.
he got the 5th season from downloading it from isohunt.com
another really good show im getting into is sons of anarchy, you should check it out.
hmmm yeah have to have a look
also i like - eastbound and down
its pretty funny, got the guy from Hotrod the movie and Will Farrell
you get your wheels yet nick?
Nah man not yet :)
hopefully 2-3 weeks.... i want em bad though then i can start buying the carbon parts i want
atm i cant really cause itll be yellow car, white wheels and carbon lips/spoilers etc.... look shit
Wonder why delivery is taking so long Nick :)
haha cause it wasnt just delivery, when i ordered them they had to get made then shipped
from the latest update should be getting shipped this or next week :)
yeah haha fair nuff what carbon parts u getin?
my mate has carbon front lip looks hawt
haha yeh varis front lip, sideskirt and rear bar extensions, wing blade and vortex generator
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
