just buy the carbon now. no one says they have to go on straight away
yeah was thinking that, little by little then it wont seem like such a big hit in one go
nice nice
should look alright when its done, sorta have an image of it in my head :)
yeh im really diggin evo's atm... in love with the white evo 10 with the black meshies no spoiler slammed....
10s look awesome
tuff evos here
http://forum.jdmstyletuning.com/showthread.php?t=107
some of the best 10s you will see..... from the US of course :)
you wont have to save as hard for the whole lot at once as well
ive got nearly all i need for all the parts anyway put aside so thats no biggie
ijust like you have all this cash then in one hit its all gone lol
hmm time to pay the bills for all the crazy arse spending the past couple of weeks. Dont want it to affect my monthly savings, so looks like ill be eating potatoes for the next couple of months haha
Take note of how close the power steering pulley is to the shroud on the right of the photo
Custom power steering lines, to make them go to the side. You can see the factory plastic U bracket where they used to pass over.
shouldnt have gone such a big rad.... wayyyyy to much effort to fit that
anyway im off
whats done is done. Others can now learn! nfi why they even produce 52mm rad's if its so much effort to fit them in. As practical as making a 100mm rad
my mate bought one... flash tune etc etc had a lil over 200 @ all 4's
he was bored with it in like 5 mins
wassup bitches
hey rekin. how well do RB20's pull?
haha asking that question in a sea of r33's, you aint going to get a good answer :)
They dont move much under 3000rpm, just need to keep it high in the rev range and she'll be right.
Lol pat your parents got sucked in by a typical saleman. My mate got me a $120 hdmi cable for my ps3. Gave it to me at cost price. $20.
lol probably, havent done enough research into hdmi cables. Something to do with the transfer rate etc
well enough to win the deca before last
hell yeah! Russel's r32 rb20 bet all the gtr's to take top spot in Deca. Its not how many litres you got, its how you use it :)
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
