fuck!!!!!!!!!!!!!!
2-3 weeks wait on getting rims shipped
turned out the storms at the manufacturers hit pretty hard and actually destroyed some parts of the machines
so gota wait for replacement parts..... although i could go with RotaOz but they dont sell the grids in gunmetal only flat black
and with all the carbon i think gunmetal will suit better, so might have to wait it out (vendour offered a refund if i wanted to back out)
becuase if a 700+ hp subaru and more cars can run grids on the track im pretty sure im safe
as Shan stated once before the grids are designed by an ex track driver
too many people have hate towards rota's because they are copies
id rather pay $3k less and use that money for other things than just one set of wheels
the grids actually have more concave than te's anyway, which is what i wanted
fuck!!!!!!!!!!!!!!
don't they just cast them in concrete held together with straws, hopes and dreams anyways? just tell em to get their mud sculptor specialist on overtime.
lol j/k.
i thought rota's were prone to breaking? or just been hyped up to that?
nah its a big hype up, there is a big hate against rotas because they are so closely copied to the jap rims
all the US evo guys run them and track on them with no problems and some of those cars are making biggg power
Anyone who was affected by the Hail storm in the south-east suburbs can apply for a Disaster recovery payment of $1000 to fix any damage to the house.
http://www.centrelink.gov.au/internet/inte...aster_rates.htm
Go into your local centrelink and ask for the form etc. Submitting mine tomorrow :D
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
