decent steak doesn't come under $30
yes, but ngas here would rather spend money on mods than eat properly.
anyways... event thrad created...
http://www.skylinesaustralia.com/forums/St...ht-t336845.html
Have to agree on the most part for that, although there are a few exceptions.
What I hate is when someone orders an expensive steak, and they want it cooked well done. HOW THE f**k ARE YOU SUPPOSED TO SAVOUR THE FLAVOUR MAf**kA?
if peeps are willing to pay extra then we should def go to Squires Loft for steak.
and yeah, medium rare max, any more and you can GTFO n take your salad eatin bitches with you.
depends on the cut of the steak and the marbling of said cut...
e.g. whereas a lean eye fillet would be best eaten rare/med rare, a heavily marbled wagyu scotch would be better cooked to medium.
if meat has a lot of fat, said fat needs to melt before the steak will be at its prime.
also if there is blood running all over the plate it means the chef is shithouse/lazy/justacook... even a rare shouldn't bleed when done properly
hey guys - long time no login - whats crackin!
What up!
WTF have you been?
Tuff kent!
Love that S13!
Wish I could go that low, only problem is I'd make it 100m from my house before hitting a speed hump!
yeh.... i can only just make it into my driveway as it is...
looking to get some steel so it's not so bad, then i'll go an inch lower :(
man your joint is like prison double speed humps or go around the park but that street is sooo farken bumpy its not funny.
tripple fail.
Have you tucked your cable/wires into your front quarter panel? I destroyed a few of mine lol mine are cable tied up but that's not gonna be good enough when I get my new wheels! I'm going lower!!!! :(
tripple fail.
Yer that's probably my fault, crashed my mums integra just after that corner cos I wasn't looking and some old bitch had parked her car on the road right after the corner... Lol
mine are just cabletied out of the way...
i havent hit any of them yet.... but i might have to relocate them when i go lower :(
spose i'll just take the FQP off and shove them inside :(
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
