you need a smaller wheelbase and better weight distribution... like an MX5.
that video was just awkward to watch. can't you do sprint days like normal sedan owners?
nothing wrong with having some fun on the skidpan. It was never my intention to get best time, thats what the track mx5's were doing. I was there to have some limiter fun and sliding around.
Although Russel in his R32 GTST won the last SAU motorkhana so sorta puts your comment out of touch :cool:
course looks like it was made for those specialised motorkhana karts, the ones that can turn on a dime.
They are the official CAMS motorkhana tracks. Very tight tracks suited for all the hardcore motorkhana guys in their mx5's and 205gti's.
Prefer them over the SAU ones because they arent designed for massive power gtr slides haha
that's exactly my point. watching a r32 gtst on one of those courses, whether it be you, russ or even that show pony ken block would be awkward cos it's like watching keyhole heart surgery being done with a mallet.
SAU motorkhana = made for big heavy cars in mind, so moot point really.
