yep, pretty much. + im gona need a sedan for work
4 door turbo skylines are not exempt as they are available in non turbo models.
they're only exempt if the model is ONLY available in a turbo variant that's a sedan and not a coupe.
LOL now go tell that to the cop that pulls you over.. err its a family sedan.. he will just dick you for every modification on it
then we will be like i told you so :)
srsly dude just get a n/a and wait like I did.. best thing is when the cop walks off and says bugger non turbo.. and its like lololol
yay, its always sunny in philadelphia is back on. Just watched the first episode of season 6 the other day. ive also got weeds which is back on and sons of anarchy, so many good shows back on to download :)
