ME?..dont think so...i work on the weekends...taking 3rd off for my birthday..then planing to take 14th of Nov for show n shine and 20th of NOV for DECA...if i add the 30th Oct full weekend...itll be too many days off ill be asking i they will prob say no to all...so not sure yet...ill ask but only if i have annual leave too...
my bday is the 3rd of November too!
i'm still going to Buller though :(
also lol @ burning Mohsen.
HEHEHE!!! mines on 3rd of october...lol...it would have been funny if ours was the same...love to smoke the streets up at midnight together..lol...oh wait cant with the GTR!!! lol...but ya...taking too many days off already lately...
these are better
Other than Crab's n Zac's Z31s in the US I haven't seen many worth writing home about.
Here's how they usually look:
Plus they drive like a bag of dicks (well to put it in perspective, it drives WORSE than a Z32) unless you do some serious suspension mods (think swapping in S13 suspension arms, R32 steering arms, IRS etc.). It's cool when someone else does it, but a headfuck to do yourself.
would rather f**k a brick
dont see that you've got much choice mate
hahah megaburns ITT
n you can't really say you'd rather f**k a brick mohsen until you actually do f**k a chick, because otherwise you make yourself look rather thick!
you should get into rapping. srs
why sellin ke hamish?
need daily
sick of worrying about epa's etc
gonna get celsior and put the profesors on it and slam + zorst it.... the end...
then the skyline can go lower + cage + fixed back + harness
need daily
-celsior and +golf and you have what I'm doing >_<
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
