ME?..dont think so...i work on the weekends...taking 3rd off for my birthday..then planing to take 14th of Nov for show n shine and 20th of NOV for DECA...if i add the 30th Oct full weekend...itll be too many days off ill be asking i they will prob say no to all...so not sure yet...ill ask but only if i have annual leave too...
my bday is the 3rd of November too!
i'm still going to Buller though :(
also lol @ burning Mohsen.
HEHEHE!!! mines on 3rd of october...lol...it would have been funny if ours was the same...love to smoke the streets up at midnight together..lol...oh wait cant with the GTR!!! lol...but ya...taking too many days off already lately...
these are better
Other than Crab's n Zac's Z31s in the US I haven't seen many worth writing home about.
Here's how they usually look:
Plus they drive like a bag of dicks (well to put it in perspective, it drives WORSE than a Z32) unless you do some serious suspension mods (think swapping in S13 suspension arms, R32 steering arms, IRS etc.). It's cool when someone else does it, but a headfuck to do yourself.
would rather f**k a brick
dont see that you've got much choice mate
hahah megaburns ITT
n you can't really say you'd rather f**k a brick mohsen until you actually do f**k a chick, because otherwise you make yourself look rather thick!
you should get into rapping. srs
why sellin ke hamish?
need daily
sick of worrying about epa's etc
gonna get celsior and put the profesors on it and slam + zorst it.... the end...
then the skyline can go lower + cage + fixed back + harness
need daily
-celsior and +golf and you have what I'm doing >_<
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
