Alex is to scared/to much of a fag that's why he went with the wide front guards. f**kn wheels f**king japan f**kety f**k f**k fcuk ahhh
:D
both engines have there advantages/disadvantages
although service on the evo piece of piss compared to the 32 even with the hicas pump removed
oil filter is a max 2min job, its arms reach underneath the car
True that man!
you're the one who admitted to having 11ty terrabytes of porn and no social skills.
370's aren't that exy, compared to say an M3. It's probably the only Fairlady other than a s30 fastback that I'd happily pay silly amounts for.
al... check out sammy from tyrepower hawthorne's 370
i'll grab photo next time i'm there
They only look good with a Power House Amuse kit on.
S30 WINS!
speaking of which when you gonna buy some rims for the taxi? and what are you going with?
im gona work some more and buy something good. maybe same rims as billy or meshies
i can already see myself dumping excessive amounts of money into it
How about I personally tell the popo you are driving a P-plate restricted car, and show them the way to your house...
they already know who i am and where i live...
you only need to hard wire it running walbros that are flow rated at 15v
in the skyline it will get around 12v from the standard setup which is fine for a bosch pump or stock pump
you will gain zero by doing a hard wire. i woudlnt do it (if i was ray), just takes time which will end up costing you more for zero gain
if you put a wallbro in there and were peaking 240rwkw then yes hardwire if you insisted on wallbro, but otherwise get a real pump - ie save cost and safety
what do you mean by real pump? nismo or tomei drop ins are a little out of my budget atm. the 040 seems to be doing the job. if i was gonna hardwire it, i'd do it myself over a weekend or something. cant b too hard
Is Bayswater too far for you?
chasers?
I was wondering what this shit about hardwiring was, scared the crap out of me at the thought I'd have to reinstall with direct feed. So just to clarify, an 040 running off the standard fuel pump wires should be completely fine for xxx amount of power?
The only issue I have now is when I "touch" the accelerator, say cruising around a carpark looking for a space, I hear a slight vibrating sound (would deadening fix this? Pump is secured pretty well to the cradle). Nut when idling without touching the throttle, or when driving I can't hear anything.
yes by real pump i mean non-walbro
you said 040 and thats fine a good model, it should give you around 260rwkw safely and easily
ive got a GTR one in mine and thats fine also, either is OK as long as its not wallbro
no need to hardwire, hardwiring the pump is bandaid for poor pump flow at normal 12v in the skyline
GTST has two stage pump control, low run and high run
when you tap the throttle the high run circuit runs and you can hear the pump more
drive around and watch ETC, SENSOR SW CHECK
youll see FP1 blip when you tap the throttle
driven an R34 GTR, and a 370z. I'd take the 370Z over the GTR anyday. Handles better, feels more comfortable, and more modern. 34 GTR's 10 years old now anyways.
Altho, R34 VSpec II or NUR I might take over a 370Z.
You WILL take a NUR over a 370Z :mad:
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
