didnt have the exhaust but i got the nismo dash. the package doesnt come with nismo turbo's by any chance :(
I believe from the S-Tune S1 packages (next step up from Sports Resetting) is when they started upgrading the turbos.
Since you having a R34 GTR, Nismo may have used R1 Turbos, if you went for their Nismo package tunes.
that was a tough r32, very quick also. his gtr is very nice too, he took me for a spin pretty much when he first picked it up lol.
Yeah true man!
so................... had the car on the "rollers" yesterday... to tune for my new pod filter - lol
the old filter was sooo dirty from the CAI that I could scrape sludge and insects out of it with a knife! and the car was tuned with that!
with the new filter on the AFR's were @ ~14.5 on full load! lol
end result was same power (285rwkw) but with 2 deg less timing... car feels so nice and snappy now
gotta retune my e85 tune next - sigh
moral of the story?
if you have a pod in a box with a CAI, check it every now and then :)
It took you how long to figure that out..? :(
I clean mine every service, then in between, then next service.
i thought the K&N and the real quality ones...also whats the difference in all these brands....some i heard are worth few hundred dollars...and some tht i use on my daily is less than 20 bucks...
anyone know any aluminium welders? need to get a custom roof rack made up for the golf. with an aluminium basket frame and birch slats for a base... so I can strap a keg and a christmas tree and a moose carcass onto. with a cargo net.
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
