Is your mates Supra that, off colour Bronze / Titanium Grey 1 with the body kit?
yeah titanium with the really badly fitting fb with horrible paint matching and hail damaged bonnet. Getting a full respray soon so should look a lot better
Ah yeah that 1...
Not my taste in Supra styling, but wait and see the finished product I guess.
everytime an R32 owner pipes up about R33's being heavy etc etc, ask them why R32's aren't over the original power to weight ratios..
i got no qalms with their weight. hell I'd take an R34 over any of em and they're the heaviest of the bunch.
they're just awkward, you know like when you meet this banging hot chick that looks epic from the neck down, but the from the neck up she looks like she's got down syndrome with a bit of dribble and snot all mixed together as it drips down her chin, and she looks up at you with those mongoloid eyes and softly utters "herp derp bunnies durrr".
you know that feeling you get? yeah... that's how an R33 makes me feel.
an R33 GTR is that same chick with a paperbag over her head.
ye driving r33 gives me instant pussy, silly dudes
so like your penis retreats into your body in shame of being attached to an R33 driver and makes it look like a vagina?
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
