Is your mates Supra that, off colour Bronze / Titanium Grey 1 with the body kit?
yeah titanium with the really badly fitting fb with horrible paint matching and hail damaged bonnet. Getting a full respray soon so should look a lot better
Ah yeah that 1...
Not my taste in Supra styling, but wait and see the finished product I guess.
everytime an R32 owner pipes up about R33's being heavy etc etc, ask them why R32's aren't over the original power to weight ratios..
i got no qalms with their weight. hell I'd take an R34 over any of em and they're the heaviest of the bunch.
they're just awkward, you know like when you meet this banging hot chick that looks epic from the neck down, but the from the neck up she looks like she's got down syndrome with a bit of dribble and snot all mixed together as it drips down her chin, and she looks up at you with those mongoloid eyes and softly utters "herp derp bunnies durrr".
you know that feeling you get? yeah... that's how an R33 makes me feel.
an R33 GTR is that same chick with a paperbag over her head.
ye driving r33 gives me instant pussy, silly dudes
so like your penis retreats into your body in shame of being attached to an R33 driver and makes it look like a vagina?
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
