guys i am due for a new phone....whats good to get? I really want to avoid iphone but if its really the best in the market ill shall...what other options do i have? any one got the new samsung galaxy? any comments on it? cheers...
Finally got my car checked out by a proper suspension place. Turns out my car is fine :) A wheel alignment will fix my positive camber.
The strut was what was bent. When I upgraded to coilovers it solved the problem.
Still not sure why 3 mechanics gave me different diagnosis's. First one said bent tie rod. Then one said lower control arm. Then 2 people said bent chassis :) Won't be trusting those kents again.
ask kriss its khoudars (spelling?) little brothers car was at winton on sunday think its runnin an rb25 from memory he was telling me but i like forget.
khoudar's 6.0? that thing is nuts!
anyone got an idea on swaybar prices? how effective are they?
cheap and massively good
because you touch yourself at night
as a previous iphone user, i can recomend the htc desire, its a good phone, or wait till the htc desire hd comes out, galaxy looks just like an iphone imo, and the case is tacky and plasticy
Still not sure why 3 mechanics gave me different diagnosis's. First one said bent tie rod. Then one said lower control arm. Then 2 people said bent chassis :P Won't be trusting those kents again.
so you're choosing to believe a mechanic who's gonna get money off you to work on your suspension and possibly sell you suspension parts to "fix" your problem... over a dude who actually crashed the car bad enough to get rid of it, and stands to gain nothing from telling you the truth.
I see.
God you're a dead set retard, you shouldn't be legally or medically be deemed fit to handle any of your own finances.
Either way if your mechanic can fix the misalignment with suspension then get it done. If I were you I'd take a string and start measuring points on the chassis diagonally and see if mirror diagonals are the same length (that's how you check for a bent chassis) instead of relying on people who stand to take you for a ride cos they've realised you're as gullible as fuck.
yes, they are. ever met someone vietnamese called khoudar?
no, no i haven't
the name khoder stems from my dads place of origin in Syria/ my mums area in leboland
interesting there are other arabs out there with what sounds like decent taste.
makes me all fuzzy inside :P
on another note, muck up day after-piss up. fkn drank half a slab. no hang over. LEGEND!
Shan, I went to Track Right and got it checked out this morning. They measured point to point from every part of the chassis and suspension. They weren't selling me anything. They checked it for free. They didn't make a cent off me. Just genuinely good guys. My workmate knows them.
So yeah, I trust their opinion over a guy who hit a gutter, tried to fix it himself, replaced everything except the strut and then thought "oh it must be a best chassis coz changing control arms and shit didn't work".
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
