My cheap trasher isn't cheap trasher anymore, bahaha...
Kinda regretted the purchase since so not many people have spare RB20 and gearbox laying around.
Story of my life...
Story of my life...
should of gone for an s13.
i rate r34 gtr's number 1 lol i love the look of them but i also love the r33 gtr's and r32 gtr's they all have something that i like about them. but this is the one car that i have ever owned that i love to drive everyday and puts a smile on my face and thats all that matters.
Story of my life...
lol where did you get the idea that a r32 will be a cheap thrasher? Its not like ive been painting mine 24carot gold over the 5yrs :O
A cheap thrasher would have been a s1 r33 gtst from the westside.
Haters gonna hate. Rollin in my r32 :D
Reason why i got a 33 gtr, i mean id love a 34gtr but another 20k for a LCD screen? lolwat?, sit in a r32 GTR and interior is aids or your girlfriend will adjust the air vent and it will fall off LOL. Front of 34 GTR = sex, rear of 33 GTR = win, if i had teh cash would make mine into a 33.4 or what ever theyre called, can always sell my xenons to help fund the conversion :D
see picture
also, ran the car for a bit
got the first plug out( the cylinder thats down) and no fuel on it. dry as a bone.
so who has a stock rb20 injector for me? lol
f**kin love this guy
u got an RB20 injector?
theyre in my car due to swapping out my Sard's for epa.
Buy yourself a brand new set of sard injectors and nistune. Should set you back $800, but at least they will last you for whatever power you want to push and nistune for future tuning.
Dont bother with GTR injectors, mine leaked after a year. Do it right, do it once. Cut corners on a r32 and it will catch up on you.
Geez who's r32 here doesn't break. Hard to come by these days :D
its an older car, what do you expect?
What I find amusing is that I cant seem to find any s1 burgandy r33's anymore. Couple years back, there were thousands of them. Now they all have disappeared. wtf happened to them
U reckon mohsen has $800 for injectors and a remap? Me no think so
haha, thats only the beginning.
Hopefully they were all written off. f**king can't get a worse combo. 93-94 r33, wine red and auto. I would take a r32 over that haha
haha the black sheep of the r33 family.
haha yeah i drained the wallet pretty well after i got it
im not looking for power gains atm
quick enough for me at the moment, so im just looking to replace the blocked injector and continue driving it
i am buying grants type m bits though :D
edit: i just told my friend(the same guy with dyslexia) that i have a blocked injector
he goes "get a nidl and put it in it"
Edited by Mohsen
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
