lolol. tpg on telstra DSLAM = fail
TPG on TPG DSLAM = win
also I ripped out all the old shitty wiring in my house and laid down fresh Cat6 cable and got telstra to come change the cable from the post to my house to a new one as well before I ditched them for TPG.
result... getting 1.5Mb - 1.8Mb (megabytes, not bits) per second on torrents.
Don't bother with customer service though, it goes to Phillipines and sucks donkey balls. Also the phone is changed to a VOIP line if you switch to a TPG DSLAM, which can suck if you're dependent on that sorta shit liek with an alarm or sending faxes like a povo kent.
Not sure what all the tech geek speak meant, but I'll pretty much only get a phone line installed at the house for internet...No need for a home phone when I've got my mobile anyway...
so how would I go about getting the good TPG you speak of? House is brand new in a brand new area too, so all the cabling will be new.
was on TPG yeah did disconnect alot specially annoying when you're trying to download stuff. no not porn.
any suggestions for nice 2nd hand meshies or similar rims for bout 1k?
sif dl porn anyway. stream bish. like you need to look at the same shit twice
can depend on the housing committee that control your estate thing. mine weren't smart enough to lay any foxtel/intenet cable. im running foxtel off satellite
life without foxtel is just not living...
Foxtel is a joke these days. The whole idea of pay tv is that there's no need for ads as you're paying for them
to run it... When we first got it back in the day ads were about 10 seconds long and only advertised the next show, but these days they're advertising products and run as long as, if not longer than free to air ads.
I download every show or movie I wanna watch and watch them whenever I want, with no commercials.
Dezz what estate you in? If it's around here I can probably give u an idea on internets
The Rise in tarneit
there's a bigger picture tho dezz... the adds NEED to be there
tv shows are made to be 22 minutes long and to keep them to half hour blocks they need to fill 16 mins per hour OR run shows at all sorts of stupid times, which pisses people off more than the adds do :rolleyes:
they also fill up slots with little shorts, but they get boring and annoying as they have to be repeated
the idea of pay tv is that you pay for more chanels and dedicated channels, not paying so you dont have ads :blink:
also nowdays on fox, 90% of the adds are for other shows on fox, and if i wanna watch it i just hit the record button and it will be there in my planner waiting for me :P
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
