Nankangs..?
Any good, I thought they were some pov pack tyres like NEXEN's, which I have used before...
nah man they are fkn shit, get what ya pay for
also lol@ that pic. Nice car and mods, but seriously, on an angle and turned in? that's like parking your car on grass and claiming it's low.
haha truth. hate the poser grass parking bullshit.
I've never owned an R32 for more than 3 years. I keep cycling through them, I sell em as soon as they're gonna lose value and upgrading etc.
I got all attached and shit to my GTS4, which is where I went wrong, otherwise I'd have gotten rid of it 2 years ago.
longest I've technically owned any car is the ceffy. Bought it for my dad in 2005?
Anyone who's owned any skyline, that's not in mint collectible condition or is rare as rockinghorse shit, for longer than 5 years, is a fool.
Wheels and calipers are awesome!
How come some times the caliper is mounted at the rear of the rotor and some cars have it in front of the rotor..?
Has it got anything to do with cooling the brake pads when mounted at the rear of the rotor ^^ as pictured above on the BMW M3... Or is it just for looks?
They are alright for now, pretty grippy. Not that I care, they are rears and dont last long anyway ;)
Slide ways action out in the Wild West-side of Melbs :/
Yeah, I thought so haha!
picked a colour that was close enough to the basecoat, but still shiny enough to look good on the golf...
Mazda Stormy Blue
totally diggin Mazda's Aurora Blue as well, but unfortunately, is a different basecoat to the current paint, which means I'll have to spend more time painting it.
This would be sweeeeet, but I doubt I'll find a sample to mix the paint off:
Having to make a claim because vicroads are a pack of ass bandits sucks.
The fact that requires to make an at fault claim sucks more.
At least something is being done...amazing how helpful just car is when excesses come into it.
Moral of story: I'm flat broke but just car are picking up the R with a tow truck in a few days to be assessed.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
