http://www.youtube.com/watch?v=yA5aR34mm9E&feature=related
Does anyone know the significance of the keyring attached to the r33 key in this video?
I've noticed the keyring features in all ecr33 advertisements?
i can understand japanese. she slaps him in the face with the flowers and says why did you buy a whale r33 when your r32 was so much better. and than she throws the keys away.
bahahahaha +1 to that
and to add to that.
GT5 has 1989 and 1991 R32 GTST (along with the R32 GTS25) No mention of r33 gtst in the game?
and to add to that.
I got a white 33 GTR in the game :thumbsup: i was suprised when braking the outside lights go on as well just like mine, i thought some fag just removed the middle lights or soemthing haha but must be stock
it seems ok i guess a bit laggier or just me perhaps? i get same problem with ns super lagggy for me
reps should go down well..
:rofl:
Coz you the BIG Hater on everything!
I will +1 you for everything you hate :laugh:
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
