how much for your rims grant?
also
i have an electric boost gauge, best to tee it before or after the t piece?
wtf you on about? Where the fark are you trying to hook it up? Behind the intake manifold is a black hose running to the standard boost sender unit (mounted on the firewall)).
Tee into that hose...there is no other t-piece?!?!!
http://www.skylinesaustralia.com/forums/topic/122508-r32-boost-gauge-install/page__hl__boost+controller
Spent too much making it go fast :blush:
Not a huge fan of those Nismo lips.. although Billy's is different isn't it?
they broken or something? :P
nah PM me when you're selling and we'll discuss.. cbf blowing $2k on jap coilovers
nah nothing wrong with em man i just want heaps stiffer for driftin/track i dont daily mine so i dont need comfort thought i did but i dont welcome to come for a spin while i got em in the car still feeel what they are like
mmm 3 more days and finally some time off
will have worked a month straight when it comes friday :(
People keep dying?
On ym gravestone, I want to have written "I told you I was sick".
http://www.skylinesa...oost+controller
thanks dude, sorry wasnt clear. i have a manual boost controler. just teed off that, close to the firewall as i can
Doesnt matter where you tee off on that hose, its all the same shit.
Did you manage to get the hose through the firewall? Pull off the inner guard liner on the drivers side. Find the black gromet and work it through there. Best is to get a long rod of some type, tie the vacuum hose onto it and push it through until it pops out near the pedals (obviously take off the drivers kickpanel etc
i got the boost sensor mounted on the fire wall and she sensor cable through a gromet.
got the gauge all connected, positive to the ignition/ + cable on my head unit and the earth.. earthed. lights to the cluster lights but nothing :/
People keep dying?
yeah never stops, this year has been our most busy year since ive worked full time for my dad
rain didnt help us either
haha, you would be the first :P
They're fins not vents..
Never really seen any XR6 turbo's with car bras, but I'm sure they make em...it's probably a flexible mesh over the cooler intake...Wouldn't really leave the bra on when thrashing it though, would more than likely reduce the air flow through the cooler
ya the fins...the car bra is only when i am going on the freeway like to shepperton for deca...the last drive up there and back just destroyed the fins...looks terrible...:(
talk to shanusr33. the full show spec white r33. he's got a custom one he uses on all the cruises. they are surprisingly exxy unless u got hookups. also be warnded: they will rape your paint if the underside surfaces aren't absolutely clean. basically a dirty car/carbra becomes sandpaper powered by the wind. also if the clasps come off, scratchy scratchy.
she'll be right though
ya ill pm him about that and see if he can send me a pic of that....thanx mate...my mate with an evo has it and it worked like a charm for him and he said the clasps dont really come off if you put it on properly...so ya
Sadly, you will be pleased to know that I just clicked through the whole lot of the pages... gee you guys can talk some shit :D
lol...thats why its called the wasteland thread...talk as much shit as u want... :P
or let your nuts hang out in people's faces and show em you don't care that they're hating on trispokes by painting em a bright fluoro colour:
this... with basti's advans would look hawt
I wanted mango but I wasn't prepared to paint the rims only to find out they don't suit... Doesn't matter now, don't have tri-spokes and 33R anymore.
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
