i bet there is heapssss more to that kfc story even the article says that other customers have provided info that the people recording had been giving him shit basically.
i worked at maccas i understand how you could rage like that i mean, think of how many mohsens are in the world.
100% he was provoked... dun make it any less funny....
anyone got a blown r33 turbo lying around??
nope but i got a perfect one you can have for $300
https://manage.crucial.com.au/cart.php?a=add&pid=114
they're giving away 300 lifetime free 100mb hosting based in sydney. use free subdomain to make it totally free. Not bad if you just wanna host some files or use it as an email forwarder etc. never know when you might need it. it's free anyways.
If you want to get arse raped by cops yes lol. Replace then with 2860-5 :)
You can get anal raped for no water in washer bottle these days... I also considered -5s but found T78 kit for 1500 but 2 blade shave slight chip so dunno.
go big single grant, check out al's setup on his 3 litre
3076 external
Maybe I'll hit him up to check out his motor and take me for a spin.
Or I retune it and see if it is any better than before. If I change the turbo(s) it would defeat the purpose of me buying GTR with at least turbo upgrade in first place.
Stick with what you got man. It's good!
Remember Al's is a 3L
30et and rb25det pistons 1200 forged, you would be mad to rebuild to std spec if you ever did it
Haven't had to do it in a while, but last time I did, filling up a water bottle was a bit easier and cheaper than returning a car to stock to clear an EPA...
True true.
And found some oil leak on the R... Damn it.
Grant I think I'll be going with -5s once I got some cashola, I'd love a high mount but don't want the cop troubles - (more so I guess) anything above 350 awkw and I'll be happy obviously will be doing a lot of other stuff as well :D but just figured if I'm modding it I may as well make it worth while. Go for lots of power! you said you were bored of 300rwkw before remember :P
Also want some CF ganador mirrors and canards and looks wise will be done :D
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
