http://soundcloud.co...1-free-download
A mates mix if anyone wants to listen to it, just helping him get his name out a bit cos his good
Not bad :) Transitions could be better though.
Getting a better deal than me :P given your age and how new the car is that's all in order. But FFS if u buy a BMW get insured with someone else. JCI charge thru the teeth then rape u for excess once u make a claim. Trust me. If anyone else would insure my gtr I'd jump ship quicker than a rat off the titanic.
$630 for ze golf. $650 for the R32 when I had it. $430 for the 240z, but that's cos it's insured as a classic show/track only use car.
All with shannons on a rating 1.
ok hang on so the $2802 is what i pay per year and the "excess" which is $1600 is what i pay in an event of an accident etc? 3046 much safer than 3047 :P
what do yous pay then for your premiums?
3k
my is250 is with JCI its a very good deal and im under 25 the premium/excess is very fair, excess as opposed to how much agreed value, i just wish someone would write it off for me. I've had an at fault claim and a not at fault claim they were really good for both
I've had both too. The only time they've been half decent has been for my 'at fault'- which theyve tarred me with because of the pothole drama. I'm at fault for a hole in the road... Ok...
I pay 3k p/yr comprehensive, I'm 22, and my excess is 2-2.5 k...
But most of all when I've had to deal with them they've treated me like crap.
not many places will touch imports either. altho M3 isn't an import so you can get it from anyone, not just JCI. isn't there a website you can compare all the insurance shit on? chuck it in one of those.
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
