Wait till tomorrow night when your balls fall off and you choose not to go again.
lol i gotta drive to carlton to enrol in uni tomorrow ;)
aye hamish wanna lift with me from the meet point? more than welcomed to drive my car so i dont have to shit myself for 5 hours :)
This was a few years ago, thats what manual / coupes were going for stupid i know. Had a lot of good things that came with it though.
i sold a 1993 r33 gts4 automatic for 9K ~4 years ago
well thats cos the parts are still new my wing mirror cost 2k for one 1200 for the plastic shit and 800 for the heated glass stuff... headlight was 3k.. *shrug* car companies dont make profit on cars any more (apparently) they make it on the parts
>_<
rip off. im kinda having second thoughts on the whole car. plan B would be a 34R easier to work on and not as expensive to run (athink). but cant justify paying 40-50K for a car that looks pretty much like what i have now..
hmmmz
Drifteks have a less aggressive angle and the spokes are different
Uras have agressive spoke angle which does not change on width of rim
Rota nfi
Bee*r have win spoke angle
lmgt's have more curved edging to spokes and angle changes depending on width
serious buziness
Cant find a 9inch pair of Uras so will probably have to opt for some rotas :(
Only 4 door 32 ive ever liked was Nick's old car. Thing was neat and subtle.
As for getting pulled over, wrong place/time you'll always get done, doesn't matter how you drive. Having a black, white, silver etc car also helps cos it doesn't catch the copper's eye as much as something like bright red...
:wub: yeah it was alright
on my p's got pulled over like 30 times current car doesnt get driven enough but been pulled over once got 1 defect i dont agree its "how you drive" depends how stock your car looks
i dunno.... both my cars looked like easy targets to pickup and i hardly every got pulled over, and if i did i was always let go
If I drive in the same direction as a cop I will get pulled over. No doubt about it. I don't give a suit anymore Neways because I know they are too dumb to find any mods/defects :)
some are but you will find some that will defect/epa you
it's cos cops don't like your drifteks pat
lol
tommy mak
worst looking evo out of all of them
agree. normal evo 6 in blue/black = win
Yeah agree, Im actually not a fan of 6's at all
i prefer the 5's... they have a more aggressive look to them
Rota nfi
serious buziness
Rota's arnt all that bad.... check my grid's they have fairly tuff concave on them, for cheap rims
>_<
hmmmz
auto plus most people had turbos back then on Ps, and a 93, I bought a 93 4 door auto for 8k when i first got Ps, f**ked it up and got a 2 door coupe manual for extra 3k but was 95 and much nicer accessories
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
