Shit is really off the chain.. I've got 1 semester left, time to make the most of it :devil:
There's a mint bitch in the full time class, damnnnnnnnn
No. There are no girls in engineering. It's like the internet.
Well cam gears will go in at the same time of the service (decided to sell my HKS cam gears to go tomei which was strongly recommended by Trent as well due to having 5 bolts rather then 3, dont want that shit coming lose ever), but will aid in the future when I get turbos / afms / injectors etc done.
Fuel filter wasn't included with the kit I got, so just added that on top (was through Kudos - Andrew is great to deal with as well) and couldn't be bothered shopping around for other air filter options Kudos only had HKS filter so just got that will be better then the current dirty as aids one in there.
So obviously I'll just be doing coilpacks, filters myself but timing belt is a bit advanced so going to a shop for that, any recommendations?
Cool!
I am sure Trent can do a timing belt for you...
No shit rashed.
Z
it's better this way.
after she knocks you back you won't have to feel akward having her in your class
Are Apexi pod filters any good? I acquired one for free :) Might put it in coz I've got some shitty "Monza" one in my car and its clogged up with all kinds of shit.
One of the best!
And you get the 'Dose' :laugh:
those monza ones are horrible
i tried one when i first got my car
and it dampened the throttle response
no idea how, but it was ordinary with the monza one
the apexi one is probably like the K&N ones
both would be good
interview done
went pretty well
will hopefully hear from them next week
lmao
really? so it was really a dood in a dress?
mannn that dood had nice legs
usually, after a knock back they want to leave.....
you know why?
Yeah will ask him about it, although I think he might send some of his customers off to GT hyper (for engine work)
Ah yeah I have been down to GT Hyper, I know a guy on AE86DC who works there.
K&N is oiled...not good for the AFM
That is the big misconception.
K&N filters are dry.
As the instructions in the K&N Cleaner Kit will tell you to apply the oil and only a thin layer... But you don't have to.
You can keep your air filter dry.
