why are u trying to buy in st kilda or elwood?
have you lost the plot? as a first house.... ?????
dude rent there instead and buy a shitter in another suburb and rent it out instead
sif buy there for your first house
haha
cheers for the advice, dont get me wrong, i have a plan in mind. :thumbsup:
assuming he's planning to rent it out, I don't see an issue with it...
I considered it when buying mine...it was either build out here, or buy an apartment in/around the city...Around the same money for a lot less house, but location location and all that shit....Decided I didn't really wanna move to the city when all my mates etc are out here, so I decided to build out here instead....
yeah its a hard choice.
Some dodgey built and overpriced appartment in the city or a full house and land package in the suburbs.
Both options have their pro's and con's. Comes down to what the buyer wants in the future.
even still if u want to rent it out
why bother if you are just going to rent it out
buy a shitter in a place like craigeburn or something and rent that out
and rent where you want to live if you insist on living in st kilda / elwood
im not convinced good rent money = good investment idea, as with good rent comes good (ie high) repayments for the land value
i would expect the good idea behind investment would be good growth
thats why i reckon its better to buy a renter in some suburb thats cheap and likely to go up
plus its easier to afford and the land is less value
just see no purpose behind buying in stkilda/elwood ?
unless you can afford it and you have tons of spare cash
    • LOL, all of the CAI like Craig I just need to put a hole saw through my bumper Done and dusted, the car runs, which is nice, I'll take it for a spin when the weather clears up Just need to put the bumper back on for good
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
