Yeah, not many of these and Characoal one pretty much as rare as hens teeth especially in series 3.
Same goes for 33 GTST that doesn't have RHS guard hole to accomodate the FMIC piping. Not many RWC place will give out certificate for the hole.
For first time I'm struggling to purchase a car.
My car has had plenty of rwc with the hole :s
If you're so set on midnight purple, buy a white one and get it sprayed whatever color u want. Who gives a f**k if it won't sell for as much as a factory midnight purple if all you want is the color.
Thought about that when I had the white one, was quoted $7-10k for a colour change and decided to f**k it. For this kind of money, I can buy turbos, PFC, wheels, coilovers, blah blah blah...
Only good thing about R32 GTR is, many of them are in Gunmetal Grey which is a colour I like most, yet I bought black one...
that sounds silly.
everything i read compared to what its doing says coil packs and or spark plugs hedging bets on somethign not right with the plugs maybe not in right or gapped wrong dunnno only a week old since it was fine before that im hoping its that
either way im gonna give it hell @ winton haha
Have you tried a different coilpack loom or ignitor? These can also be responsible for the misfire.
took car back they wound boost T down they rkn that was causing the problem so need new boost controller
This might fix the issue but only by masking it. Could be an underlying fault in the ignition that only shows its face under higher boost.
man im gettin over checking into wasteland
it salways same shit cant sell my car, buyer fkd me over, cant find a car to buy, oh didnt buy that car it was shit cos XXXXXXXXXXXXX
more importantly winton was fkn awesome car was really solid all day
Birds - yeh car is going back friday for more changes to get it right dont need it for a few motnhs now so was just about getting out there yesterday which i did so :D:D:D:D
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
