Members only detailing day posted :D
http://www.skylinesa...-detailing-day/
Should be awesome.
Also Advanced day to come in future
Ah yes, Hamish mentioned this at the SAU General Meeting.
Sounds interesting.
A bus carrying only ugly people crashes into an oncoming truck, and everyone inside dies. They then get to meet their maker, and because of the grief they have experienced; He decides to grant them one wish each, before they enter Paradise.
They're all lined up, and God asks the first one what the wish is. "I want to be gorgeous," and so God snaps His fingers, and it is done.
The second one in line hears this and says "I want to be gorgeous too."
Another snap of His fingers and the wish is granted. This goes on for a while but when God is halfway down the line, the last guy in line starts laughing. When there are only ten people left, this guy is rolling on the floor, laughing. Finally, God reaches this guy and asks him what his wish will be.
The guy calms down and says: "Make 'em all ugly again."
It doesn't surprise me that most people think the age of consent is 18+, the laws are as vague as that friggen book^. It's like they purposely avoid saying that if you are 16 and over, you can have sex with anyone over 18 provided there is no duty of care or supervision between parties and it is consensual. Was that so hard? Instead they leave a myriad of clues towards it, stating what you can't do, instead of saying what you can.
From a book I got from year 11 VCE, "The essential guide into adulthood"
You have this at school?
I didn't get any of these when I was in school.
Get to travel to Cairns next week for business already woot already loving this job :thumbsup:
What do you do for living now?
I hope it pays enough for you to spend on the R.
The line has already been pointed out, and it's 16.
Not sure what gives you the right to call any of us "pedophiles" when we're not breaking any laws AND it's all 100% consensual?
Legality is one thing. By the eyes of the law your fine. To the eyes of everyone else you will look like a pedo. Not to mention most 16,17 year olds are head f**ked
bs man
clearly this is based on no hand no field work what so ever.
virginity confirmed.
Yes i was gonna day wtf is Mohsen commenting in this. He prob never seen a pussy that wasnt on his computer screen
guess they figured you werent gettin any :rofl2:
this.
dont give a fk if its legal a 20+ year old with anything under 18 is a pedo.
It is the Crimes Act after all.. not the Where You Can Put Your Dick Act
But luckily I speak fluent Legalese :D
bs man
Immaturity confirmed.
Wait, so when you were my age you were not hangin for anything that came your way?
That said there are exceptions (eg: boz spec) and remember I am 18 so the age gap isn't that different to me.
As for someone else here. Hypocrite!
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
