On the topic of catch cans, I have heard good and bad things about them. Some people recon that the vapor helps to keep things lubricated. Where if u put the catchcan in it will take that away. Dunno tho, what are peoples thoughts on this
Speaking of which.
I keep seeing a white Lambo out the front of my work, Asian student gets out each time and goes into the student accomodation block across the road... lol.
I see AMGs and all sorts of other thumping cars and sometimes with P plates on them
It's seriously taking the piss @ reality.
That Asian student is my cousin.
Hopefully this asian dude has no appreciation of money :)
Other dude around here about 21 or so drives a late model lambo... His dad owns viking transport
His dad is my uncle, so yeah that's my cousin too bro.
Spacers are cheating, like a push up bra really
:rofl:
That is great!
LOL. I know. It was only 5mm though. Most people would say I was being anal, but knowing my rears were tucked in by 2mm just did my head in.
Really, so having the pipe work 10cm in, 10cm out. With for instance 100cubic mm of surface area for the oil to come in contact with. That is going to
perform the same duty as 45cm in and 45 cm out with 450cubic mm of surface area for the oil to come in contact with? Surly the more you can
break down the vapor the better?
but yeh maybe he is right, the air may not 'slow' down as such.
after 30 odd track days my can only has residue inside it and the intake pipe is clean.
yeah maybe this is one for mythbusters cause your idea is definately plausable and works well for you ..
its true, i never use a catch can when I sex
Haha, then that would be his sister i was talking to the other day, she drives a beamer and is smoking hot in a mini skirt and heels :)
Either way there are a million different ways it could be done.
eeerrrrr yeh wat thinking more like keeps the butterflys lubed not your wang
Negated by the fact the oil vapor is effectively lowing your octane ratting, thus causing or leaving you open to knock.
but isnt some blowby normal?? dunno guys im just saying i've heard arguments for and against have have nfi. I dont run a catch can atm, my cars not really modified to the point where I would need one.
:rofl:
That is great!
Even better, tell him to do some good prices on the stuff for me.
Is that how you know Jess?
The asian or the lambo dude?
    • LOL, all of the CAI like Craig I just need to put a hole saw through my bumper Done and dusted, the car runs, which is nice, I'll take it for a spin when the weather clears up Just need to put the bumper back on for good
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
