Nice drift angles :)
these are awd's though arent they? thats why they can bring the car back from such impossible angles. ive seen tiff needell do it in an audi before he said all you got to do is throw it in and when you want to correct it plant your foot and it straightens up.
all i can see is some rich dude played forza 3 too much an decided to reenact it in real life
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
