no offense but only dumb kunts feel the need to get pissed in order to have a good night out. if you and your mates are that boring you should start hanging out with people that are "loose" without alcohol, and maybe spend your cash on something that won't make you look like an idiot instead.
in other news, i got a brand spankin toyota yaris, 1300cc's of doom!
Yeah, you're not picky hey Jamie? :P Take whatever you get yeah?
That's kinda my attitude at the moment. Works well haha. But if I had a preference, BRUNETTES. And asians/wogs :thumbsup:
I've always been a sucker for a blonde
Blondes would be my fav.
Then Dark Brunettes
no offense but only dumb kunts feel the need to get pissed in order to have a good night out. if you and your mates are that boring you should start hanging out with people that are "loose" without alcohol, and maybe spend your cash on something that won't make you look like an idiot instead. In other news, i got a brand spankin toyota yaris, 1300cc's of doom!
Rimon your such a killjoy lol
Loosen up man. And a yaris? A f**kin yaris? How did you end up with a yaris?
Haha yea man whenever. You will prob be more interested when it goes on e85
Haha sick. Maybe one night I'll drive down with another random girl and go for a spin :P Or come past mine and pick up me and my brother. I reckon he'd love it!
i'm loose enough to not need alcohol to loosen me up. dickface.
yeah it's a courtesy/rental car, looks like a washing machine. problem?
black hair + blue/green eyes = win
You certainly sound loose :ermm:
I agree people should be able to have a good night out without alcohol, and I dislike it when it is a prerequisite, or when peoples social skills are dependant on it...but to each his own. I can have a great night without alcohol; alcohol can enhance a night for me too. What pisses me off is when people try to force me to drink, as if it will somehow impact their enjoyment of the night.
Hey wasteland boys and girls,
Please 'like' my car picture on the justcar facebook page! If I get enough 'likes' I get a magazine or something :D
First you might need to 'like' Justcars to be able to like my car picture.
Just cars:
http://www.facebook.com/home.php?#!/justcar
My car:
http://www.facebook.com/home.php?#!/photo.php?fbid=215403871808974&set=pu.130076853675010&theater
Thanks guys :D
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
