heathcote use MPH on their timeslips, somehow i doubt he converted it himself
My bad, I thought he was talking about hitting the limiter at the end of a straight at Winton.
Good man, went to crown a bit later on to see a few mates. Will definitely be heading back to Jett Black.. some absolutely bangin ladies there
Nice! Crown is a good finish up. Tell me about it, glad it's back to it's old ways. Shame the dance floor got so crowded. We left not long after some douchebag tried to start us - think it might have been one of Mohsens mates? Plenty of lulz were had at Elsternwick Maccas too.
Shame it's white.
Buy it anyway
would have to be pearl white or black or blue. don't like the silver most of em come in or the red...
i'm pretty keen on it just waiting for CGU to sort out my $$$
in other news, hit 150km/h in the yaris. machine.
Birds/ ric, nah man we were in Heidelberg. Think I'll have to come along one night with yalll :)
You can replace GTEES as the annoying 18 year old that cockblocks everyone :thumbsup:
I don't think anyone will let him drink that much again. What a handful >_<
Shoulda bashed them for the lulz.
Also Leigh don't you have a powerFC? How can you have been hitting speed limiter? Probably just not enough power to crack 111mph.
Nope stock ECU, need to get a power fc badly, and its definitely the speed limiter it just cuts all power and is like a rev limiter and goes DUDUDUDUDUDUDUDU really fast near the end of the strip. The 12.6 I ran was at 105mph so must of been a quicker launch or something.
It takes a while to get the yaris to 150km/h, I have tested this in the pizza hut car when I delivered pizza.
Shes alright, doesn't do anything though.
Screen shots tomorrow :P
Carol's not bad lookin. I'd tap that. Maybe.
Doesn't want you for your wang tho clearly, just wants you for your wheels. Well played.
Also, is Josh your lover?
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
