heathcote use MPH on their timeslips, somehow i doubt he converted it himself
My bad, I thought he was talking about hitting the limiter at the end of a straight at Winton.
Good man, went to crown a bit later on to see a few mates. Will definitely be heading back to Jett Black.. some absolutely bangin ladies there
Nice! Crown is a good finish up. Tell me about it, glad it's back to it's old ways. Shame the dance floor got so crowded. We left not long after some douchebag tried to start us - think it might have been one of Mohsens mates? Plenty of lulz were had at Elsternwick Maccas too.
Shame it's white.
Buy it anyway
would have to be pearl white or black or blue. don't like the silver most of em come in or the red...
i'm pretty keen on it just waiting for CGU to sort out my $$$
in other news, hit 150km/h in the yaris. machine.
Birds/ ric, nah man we were in Heidelberg. Think I'll have to come along one night with yalll :)
You can replace GTEES as the annoying 18 year old that cockblocks everyone :thumbsup:
I don't think anyone will let him drink that much again. What a handful >_<
Shoulda bashed them for the lulz.
Also Leigh don't you have a powerFC? How can you have been hitting speed limiter? Probably just not enough power to crack 111mph.
Nope stock ECU, need to get a power fc badly, and its definitely the speed limiter it just cuts all power and is like a rev limiter and goes DUDUDUDUDUDUDUDU really fast near the end of the strip. The 12.6 I ran was at 105mph so must of been a quicker launch or something.
It takes a while to get the yaris to 150km/h, I have tested this in the pizza hut car when I delivered pizza.
Shes alright, doesn't do anything though.
Screen shots tomorrow :P
Carol's not bad lookin. I'd tap that. Maybe.
Doesn't want you for your wang tho clearly, just wants you for your wheels. Well played.
Also, is Josh your lover?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
