Well I knew I could count on you guys for sensible financial advice.
I saw the blue one too...love the colour...not a fan of the wheels. I think if I was to buy an RX7 it would have to be red or black. Can't believe how cheap those two are though...it used to be mid to high 20s for a half decent example.
^^ This!
Well Red for me.
Or a white one would be nice too.
When you consider it, what else is available for the price that looks that good...a real decent R32 GTR with an extra 10 years on the clock...a thrashed out R33 GTR...an Evo 6/7?
15 grand worth of overnight parts from Japan...
you can daily a thrashed 33R no worries
try doing that with the FD...
And this is why you're not dtf.
Half the people I stay up talking to are older than me. I fail to see how it makes me a 15 year old. Some would say having a 60% ban warning is immature Alex.
lol not with the way this place is run got 20% for calling someone a pole smoker :rofl2:
but seriously staying up 'sms'ing' till 2am i did that shit in high school
get ya self a decent internet connection and a webcam.
haha man i could get 100% in 1 post thats why i dont bother anymore just post here and thats it.
shame really i barely bother with technical shit either, cos meh cbf.
DCUPS is win, but not the last car he had LOL
The RX7 was the last car he had :P He has an Audi or something now. He basically had to move on from the car scene to save his marriage lol. Poor guy.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
