they are nice. remember your GTR would of had better potential for speed but for everything else they are mint
edit: my mistake they still are quicker than i thought just wikied them
8:22 nurburgring time :thumbsup:
yeah they are quick for what they are but of course it wouldnt take much to make a gtr faster. maybe ill get the one on carsales up in queensland thats been supercharged and making over 400hp atw.:D
R33 GTR seats - Worth buying? Dont see anything wrong with my stock seats, but i might not know what im missing out on?
r33 GTR seats or r32 GTR rims w/ semi's
hmmmmmmmmmmmmm
33 GTR seats are ok for light track work, they don't really have great side bolstering or shoulders. Don't worry about semi's, just get a set of soft road tyres (RSR, AD08, R1R)
R34 GTR / Eastbear, Recaro or Gais style are probably better suited to a harness though.
32/33 GTR seats are not that great for harness as it has to go through the hole in the middle and will cut into your neck annoyingly.
for a lil tacker like you leigh there are HEAPS of reclinable options from bride that are much better than a GTR seat for track/street usage :)
Haha true that Hamish for now they are good enough I feel. Turbos and supportive mods first :D
Also how much for a base tune with a power fc? Picking one up tonight and wondering if it's worth throwing in while I save for the turbos and other parts for a bit of fun in the mean time. Even if its a bit rough I'm sure it'll use less fuel then I am now stock ecu must pump so much in after you boost it up a bit.
Wow that was annoying to type on iPhone.
Standard price is about $500
I read some threads in the Vic section, but only if they're relevant to me/interest me
F1 thread, and sometimes browse the general wasteland, but most of it is internet nerds posting pictures with word art on them which they think is hilarious.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
