I managed to change pads without removing calipers in Skylines.
wow. Well i learnt something new today, i never even thought to attempt it.
Kaz buy your pads somewhere, go into a mechanic shop and tell them to fit them for 30$ no questions asked if they say no try another shop. If they say your discs need machining say i dont care. It should only take 30 min so sit and watch them like a hawk..
Or if u feel confident just do it yourself
see this is the only thing that stops me halfway through lol .... the male brute force..
pulled off my radiator hoses no worries but this one vacuum hose.. FCKME too hard, still cant get it off
i probably have even less strength than you do though.
AND..
I don't want to go to school!
Ok few tips
leverage is your friend
hoses come of a lot easier if you warm them with your hairdryer first
and it is best not to say things like "FCKME too hard" when you're in a room full of men :P
It's easy. Hardest part is pushing the pistons back. Nothing a set of crowbars can't fix
+1, I used long screwdriver once but thinner and flat surface crowbar is ideal.
no screwdriver? you need crowbars? =(
If you have long screwdriver, you can 'push' the pistons with both hands, but long and flat surface crowbar is easier.
I have no upper body strength at all. Kinda look at it uselessly and then call my mechanic... Or bf... :P
I can change a wheel though!
