Zuck me Alex. Blitz return flow ftw...all return flows need some reo choppy. Blitz is atleast a quality item and looks good when done.
fb is legendary for finding awesome ppl i lost touch with like 7, 10 and 13 yrs ago.. no contact details til now.. too hard to keep in touch when you move interstate and all that shit
If they were so awesome, why did you lose contact with them in the first place? People move on, it's normal. Sustaining contact with people you don't plan on seeing in real life is pointless IMO. And so Facebook destroys the need to see people in real life if they can perform social responsibilities from the comfort of their bedroom. As it has done to so many people...
because I moved to Melbourne? Back when few ppl had a mobile phone and/or email? Would you like my life story? How exactly did this become an opportunity to give me shit? Actually I have SEEN and fully intend to see the rest of those ppl I haven't seen in years when I next go to Sydney or they come here. Those friendships are strong enough that I can *not* see ppl for 10 yrs but can see them tomorrow like no time has passed at all.
And they had no house phone or mailing address? Reality is, if you really want to stay in contact with people, you will without the help of Facebook's past digging services. People did it long before Facebook came along.
im justgunna chuck this out there, i dont expect alot of support.
But am i the only one who thinks blags car looked better with the old wheels. i mean the enkeis are awesome but the car looks fat and bloated with them, whereas it looked more sporty before
so whos with me?
I got bored of xd9s, became to common for me... The enkei's aren't too much bigger that what the xd9s were.
Sporty enough?
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
