dunno where that is lol
this guy trains at fenix point cook his afkn beast always has green wrfl shorts on tatts on shoulder/arm fit as all hell guys an animal wouldnt wana play against him :wacko:
Green shorts, probably Spotswood...Yellow lettering?
Probably play him in 3 weeks..lol
Dragged some VT clubby after lunch today - was lols. (to the speed limit anyway)
Lol asif bother with that.
Had some dumb shit in a black r33 go at me. Lets just say he was waaaaay back. Comes and asks me my power at the next lights and claimed he has 280rwkw. I just looked at him and went. "no mate you don't. This is 280rwkw." his passenger was pissing himself laughing.
and LOL @ 3/4 filling a tank for economy... All of what, 5-8Kgs of weight? hahaha... i cannot fathom...
You'd get better gains running 4psi more in the tyres.
And filing up 3 times a week = you be paying more @ worse times = less economical
That blokes a f**kn machine!
Try driving a 4cyl car with barely much more than 200kw, you feel the difference, trust me!!
Like if I have a 100kg friend in the car the bloody thing just doesn't move. Not like my ZX when I could have 4 passengers and still get pushed back in the seat a bit.
actually ther arnt all bad
evo goes all with car weight of 1400kg and 205kw
even with passengers
I doubt a little tuna can car has as big of a tank, i bet its single figures!
Im waiting for the next idea of leaving the spare tyre/jack out for weight reduction.
Or like that other idiot in the Skyline Discussion who removed the A/C to increase fuel economy/lighten the car LOL...
I said 3/4 is the max I've ever put in. It normally sits around 1/4. I put in $30 when it gets close to empty.
Also if it's expensive then I'll only put in about $10 and wait for the price to go down. I only put in $30 if it's cheap.
Weird system but it works for me.
EDIT:
Lol @ tyre/spare jack..... I removed my spare tyre and tool kit the day I got the car :P
Edited by jezza boii
i bet your fuel system likes all the shit floating around from 1/4 tank too
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
