you sound like a fkn 16 year old horny little kid who comes in here and brags everytime a girl walks with 8kms of you. it was like a broken record 20 pages back and your still going.. its really sad and frankly i dont think anyone hear gives one bit of a fck about you and your knob and its travels.
i have sex everyday... and?
jus sayin.. dont take it all personal either we got sick of grant and his car whingers to.
If you tap everything that moves that would make either of the following true?
- You are Bi
- You have an STD
- You father many children
- You are a male gigglo!
- Your father owns a Viagra manufacturing plant
If you can't answer yes to any of the above then you are full of Sh!t
Yep I have.
Just need more mods though!
What did you get?
Come on gents he hasn't answered my survey yet. lets wait for an answer, before we flame to much. :whistling:
Who?
:cheers:
16 yo dipping the knob in anything 8km away guy.
Ah this bloke with hairdressers car?
:rofl:
Jamie, since you're too lazy to read few pages back, someone asked me exact question few days ago.
I bought 33 GTR in Midnight Purple, no compliants had her for more than 6 weeks. After nearly a month and half without a car, feel so good to be back in proper car that you can fit front bumper inside.
LOL!
This guy!
Well done man and enjoy the GTR.
LOL!
This guy!
Ta, enjoying her so far, have few mods but may change them...
soo.. its fkn freeeeeezing outside.
Yep, tried to work outside changing front bumper, only get as far as taking the grill off and off to inside I went.
Global warming? My arse!
I can safely say that I've never been to a "LAN party"..
You know how i know you're gay?
Nar...fark being around girls all the time. Yeah they can be good eye candy and it's cool to chat up / dance with them, or even have sex with them occasionally, but there's only so much I can take of the female company. Male mates are much better entertainment IMO...better laughs...better conversations...better at games...better at drinking. Jerk off before you decide what to do for the night...you'll choose Playstation :)
+1
Sitting around sinking beers, shit-stirring and abusing ya mates that you certainly cannot do with chicks around = good wholesome entertainment.
chuck up some pics of the new ride :thumbsup:
Will chuck up couple of pics when I finally get rid of ugly ass 400R bumper + skirts.
What mods and plans?
So far, I'm telling myself to do zorst, BPU and PFC.
But wanting more power badly...
Got coilovers but am swapping for harder ones this w/end.
Got wheels that I impulse bought a while ago only to find out it's sunken on stock height even though it's 10.5" wide! So different wheels will be purchased.
Also on wish list, Nismo cluster, xenons (unlikely), turbos, blah blah blah....
I've received a deposit for the front bumper today pending my removal of the bumper.
I'm putting stock one with N1 vents in, still need to find someone to replace the skirts though - been slack lately.
And then it's off to DECA right?!?!?!
:P
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
