34R / Eastbear seats are ok for track work. They allow you to still have feeling in your ass once you arrive at the track as well.
32/33 are almost useless as the shoulder wings are not large enough.
And get some KU31's they own in the wet from all reports. They cost more than KU36 for a reason....
How is your car now Hamish that is sounds like s Saab wagon?
+1 for no shoulder support but they fit my bum great :) its also handy not having sides when you have to deal with a ballin kid in the back
+1 for KU31s got a full set for the misssus car for 540$ and they are great in all conditions and they ride is really nice and comfy to...will be better when I get my koni yellows from the states, 600$ for a full set = win
dont do it!! I have em on my car pretty good in the dry shocking in the wet!!
i would consider another tire since its winter and aint gana stop raining
jus sayin have a read on them :thumbsup:
that's just a load of shit.... ku36's are nowhere near as bad in the wet as people say.
for some reason people buy 36's and expect the performance of an RE55, it's NEVER going to happen
they are NOT a semi slick tyre, they are just a street tyre. they perform fine in the wet for what they cost/are. and yes I have used them on many occasions
i should know in less than a week :)
volvo motor FTW
volvo motor FTW
I dunno about you guys, but I can't buy or consider buying performance/sports cars I've beaten in run ins with my near standard R33. They just seem to lose their appeal after that. MPS, XR5 Turbo, Golf GTi, Cooper S, list goes on. Makes me think, why bother buying one of these when such an old car will just do away with it. Not saying the new cars have to get faster and faster, but they better have something special to offer and above a 15 year old Skyline that's all. Aesthetics and fuel economy maybe? A better feel? Not performance though...
there all phag ass cars anyway so why would you.
personally i like luxury over performance for daily duties
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
