I have twin 60mm exhaust for my R, lately, I've been liking HKS super dragger exhaust.
Not sure if I should sell the twin exhaust for HKS (meaning I'll have to source front pipe that is 3.5").
S2000 > R33 GTST S2? I'm thinking of selling the skyline and getting an s2000 in the near future. Good or bad idea?
Good idea. I was heading down this exact path a while ago...still haven't ruled it out. Have you driven one yet? I was never a huge fan until I test drove one. They feel like a big go kart, nice and tight, very capable feeling and easy to drive, fun little car. Only thing I gave my Skyline over it was the performance factor. Obviously a lot harder to extract that out of the Honda, but they do alright as a standard car. I think S2000s have dropped in value as much as they are going to. Keeping in mind they were an 80k car brand new, you can now pick them up between 20 and 30, it's a bargain. Try and get one with a glass rear window rather than the perspex.
Depends whether u like the stigma of being referred to as 'the fool runnin a Honda 2000' *insert drawn out american accent*
why? that's the equivalent of owning a 33 in oz.
Z4 sucks unless its the hardtop ones even then needs to b an M or something.
They suck for space too boot doesn't exist and a4s are just nasty unless it's te new model full specced
haha the z4 super factories documentary is pretty cool. Have a watch of it, if you havent before.
+1
Two friends of mine have Integra Type-R's and they move pretty well. S2k would only be better (and rwd too). Havent driven a s2k before, but if its better than what the Integ Type-R can deliver, then no doubt it would be a great car. Get one, and give me shot at driving it :thumbsup:
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
