they are nice. remember your GTR would of had better potential for speed but for everything else they are mint
edit: my mistake they still are quicker than i thought just wikied them
8:22 nurburgring time :thumbsup:
yeah they are quick for what they are but of course it wouldnt take much to make a gtr faster. maybe ill get the one on carsales up in queensland thats been supercharged and making over 400hp atw.:D
R33 GTR seats - Worth buying? Dont see anything wrong with my stock seats, but i might not know what im missing out on?
r33 GTR seats or r32 GTR rims w/ semi's
hmmmmmmmmmmmmm
33 GTR seats are ok for light track work, they don't really have great side bolstering or shoulders. Don't worry about semi's, just get a set of soft road tyres (RSR, AD08, R1R)
R34 GTR / Eastbear, Recaro or Gais style are probably better suited to a harness though.
32/33 GTR seats are not that great for harness as it has to go through the hole in the middle and will cut into your neck annoyingly.
for a lil tacker like you leigh there are HEAPS of reclinable options from bride that are much better than a GTR seat for track/street usage :)
Haha true that Hamish for now they are good enough I feel. Turbos and supportive mods first :D
Also how much for a base tune with a power fc? Picking one up tonight and wondering if it's worth throwing in while I save for the turbos and other parts for a bit of fun in the mean time. Even if its a bit rough I'm sure it'll use less fuel then I am now stock ecu must pump so much in after you boost it up a bit.
Wow that was annoying to type on iPhone.
Standard price is about $500
I read some threads in the Vic section, but only if they're relevant to me/interest me
F1 thread, and sometimes browse the general wasteland, but most of it is internet nerds posting pictures with word art on them which they think is hilarious.
Guest
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
