  • Replies 128
It is all to do with the Power/Weight ratio, here are the figures for the R33:
RB26DETT Engine – 137kw/tonne
RB25DET Engine – 127kw/tonne
RB25DE Engine – 2 door 110kw/tonne
RB25DE Engine – 4 door 102kw/tonne
RB20DET Engine – 109kw/tonne
RB20DE Engine – 73kw/tonne
Here is the info from the Vic Roads website:
High Powered Vehicles
All probationary driver licence holders are restricted from driving a high powered motor vehicle on a highway. A high powered motor vehicle is defined as a motor vehicle (not a motor cycle or motor trike) which:
has a power to mass ratio which exceeds 125 kilowatts per tonne; or
has an engine capacity which exceeds 3.5 litres per tonne of the unladen mass of the motor vehicle.
* Information regarding high powered vehicles can be obtained by telephoning VicRoads on Tel: 13 11 71
If you have a slightly heavier than normal R33 GTST you will be ok.. according to the law.
no nothing can happen. Ive been in this situation had a talk to the officer who was trying to get me. Because there is no official records of skyline gtst of there power to weight i went to nissan and asked them and they said the only way to get them would be from nissan japan. So the officer couldnt do anything about it. Thats the only trouble ive had with the law trying to stop me once. Other times they dont know nothing about the car, such as calling a front mount intercooler a radiator and saying my stock blow off valve is illegal because no turbo cars have ever come out with blow off valves? weird...
does anyone have any experience in getting dcked for this...do the cops know that a R33 GTS-T is going to be over...and is it possible to get your car detuned to run under the weight and have a signed machanic sign it or something...is there any way around this rule...i'm about to buy my first car and i want it to be an R33 GTS-T but i don't want to buy it and have it sit in the garage for 3 years while i drive some sh*tbox
if u do get caught do u just keep getting fined or wats the penalty...is there any way to legalise an R33 GTS-T using a machanic to detune the car...would this be good enough...and do the cops know wat to look for/know the specs of the R33 GTS-T
The power to weight laws were introduced months before i got mu p's many years ago, I obeyed them and managed to drive cars that were faster than the typical illegal cars (like 6cyl cortinas and v8 commodores), without any undue problems from the police. If you drive a turbo skyline on your P's you are asking for it.
A naturally aspirated skyline is plenty fast for an inexperienced probationary driver, and shows maturity in accepting this fact.
Don't get me wrong, I deal with many probationary drivers and share their enthusiasm in the world of high performance cars, but this is real life not NFS.
At the end of the day some police will know enough to book you for power to weight and some will not, on the other hand some cops will see 'Turbo' and dick you anyway.
This has been a community service announcement brought to you by some old intoxicated tool that is taking a break from modifying his turbo skyline in his garage!!!!! :):D:D
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
