  • Replies 102
BOVs are used for the following reasons (if my googling can be trusted);
- prevent compressor surge
- reduce turbo and engine wear
- maintain turbo speed during gear change (to reduce lag)
What he said.
There is no benefits of running a aftermarket blow off valve unless your running really high boost. Just retain your stock one. Going by your username if you have a GTR, GTR BOV's are really good and more then sufficient.
i think he's asking the pros and cons of with or without a bov, not whether if it's aftermarket or not.
Well the only pro of not running a BOV would be less weight, less piping.
Hardly see those as any gains to be had.
Not going to debate the effects of turbo damage from lack of BOV. That is another topic.
Basically, I'm just going to say there is no real benefit in removing the BOV. Just make sure if you have one that it is a plumb back.
Lets consider for a minute the fact that most race cars don't run a BOV.
Lets consider for a minute the ONLY reason they were created was for emmisions reasons.
Lets consider for a minute the only people who started spouting about engine wear and turbo wear were the manufacturers of aftermarket BOVs...
The only thing they will do is remove "dose" (Which is perfectly fine, non damaging and doesn't slow the compressor down)
I run a MASSIVE fark off turbo, laggy as hell, and between shifts, it comes snapping back on full boost. The real way to setup a wastegate will prevent lag between shifts from not running a BOV... :blush:
    • Mixing things up - installed some leather recaros to match the leather seat covered rear seats. Interior looks pretty schmick now except for some slight wear on the steering wheel which I will monitor and address if it becomes worse or actually noticeable!
    • Didnt realise RB's had more then 1 head.
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
