Cheers
How does the .68 T4 compare size wise to a GT30 .63?
3" outlet?
Sorry for all the questions lol just trying to figure out whether I should lump it with a custom manifold for a td06, use my TD07 or sell it and get one of these.
Plus im a bit of a geek when it comes to this stuff lol
LOL only just noticed the intake temp, went to post and you had already posted...
So dodgy temp correction and boost wound up so high the dyno can't even read, INTERESTING
this is a stupidly high ramp rate to smooth it out lol, don't doubt the power, just how smooth it is lol
I attempted to enter a negative figure into a DD Dyno to check correction factor but it didnt except it. I tried IT of 1 dergree C, 12.5 and also tried unplugging the temp sensor and got the following corrections. Wishful thinking but imagine if the dyno was removing another 10% from the figure... :)
Thats generally been my understanding - the greater the intake temp exceeds the ambient temp the greater the correction (inflates power) and vica versa (deflates power). So there is no correction where intake temp and ambient temp are the same.
After looking at the graph this morning, Chea though there was a bit more in it :)
Starting to lift the head at that power so we're gonna have to leave it there for now. Have the Motive drag challenge next week, after that put a Tomei head gasket on and a 6262SP!!
I'll start making the vid
awesome results PJ well done,
but
Look how the power drops up top....
Quick everyone should start hating precision turbo's like you hate Hypergears... :)
This engine doesn't have valve springs, don't think they'd be loving life right now. It would be to interesting to see if the power would hold flat then (some studs and a head gasket would help us too)
We'll log it @ the track for you :) Can't wait it should see close to 135mph trap speed!
  • 3 weeks later...
Well we've since replaced the head gasket in the S14, and while it was apart installed ARP head studs and a BC valve spring and a retainer kit, which has allowed us to rev the engine a bit harder.
The result was 392.3kW at the wheels with a 35psi spike which fell down to a stable 33psi.
For the guys who were sceptical before, we ran it at 29psi and got 367kW at the wheels. So there it is, the limit found of a 5557. Pretty crazy stuff really from a baby .63 exhaust housing!
If the weather is good tomorrow we'll be taking the car to WSID on full slicks :laugh:
Here are the sheets
And now for the Skyline lovers, here are some pics of the R34 that we're building, you can check out a full spec list on our site at: http://www.powertune.com.au/projectcars-gtr.html
It now features a BC 2.8 and Precision GT4271R ball bearing billet turbo, Powertune twin scroll manifold, hopefully we'll have it run in and tuned by the end of the month, then of course straight to the drags :P
Was not skeptical before... Was just noting that you had used more boost than you were claiming!
I myself am super impressed with your results, so much so that if you get your ass into gear and test a 5557 0.63 on a RB25 I would be very interested in purchasing as I'm just about to do a 25 conversion on my 32 this month and looking at a few options for turbos at the moment :)
Edited by SimonR32
Bit of an update for my rb25+5557 combo...
Picked it up last week (arrived in aus the day before) semi tuned.... still having dramas! Electrical/ignition, burnt the clutch the first night, no vct still, only 18psi atm on a verrrry conservative tune.
Feels good to drive with off boost, it starts making good power from 3k onwards.
I'm glad powertune has pushed this turbo to it's limmits... I wasn't going to push 30+ psi into my stock rb25. I'll see where we go at 250-260 odd on 98.
Cheers
Justin
I myself am super impressed with your results, so much so that if you get your ass into gear and test a 5557 0.63 on a RB25 I would be very interested in purchasing as I'm just about to do a 25 conversion on my 32 this month and looking at a few options for turbos at the moment :verymad:
Yes the results are awesome, this time we turned it back to show that we were telling the truth about the boost though, as I can't show you the log on the Haltech... well I could but it's too much mucking around for a busy workshop.
As mentioned previously, we will offer free tuning to a donor RB25DET owner wanting to put one on a 5557 purchased from us. Don't be shy guys :) If we had an RB25 as one of our project cars it would be on it!
The turbo's and all other info can be found on our website.
And the 6262SP will be going on the S14 next after we race it, 40psi here we come. Wonder how/if the standard bottom end will let go!!
    • Johnny is sad now... Because you didn't get Bosch Motorsport ABS.
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
    • So...not sure if you know if that has always been there or why you went looking. It could be old damage from a clutch explosion, or even just the gearbox got dropped somewhere along the line. Basically, you should seal it up to stop oil and dust getting into the bellhousing, but it doesn't matter too much and is not structural. I'd suggest something like a glob of JB Weld. BTW what gearbox oil are you running, I would guess the breather has been spewing it everywhere.
    • Hey Duncan thanks for your reply. Sorry mate I know the photos are shit.  Took another photo for reference. Seems the casing does have a hole in it looking on the net, fluid seeping out. Added a photo
