Going off Jez's result it does look like the 6262 is hard to beat for a quick street/strip car without the need for gas or a huge converter.
Looking forward to pumping 30psi into my JZ with one....
*le sigh - one day I'll get there lol
You gotta have something to work towards!
Your car is running now at least, which is a good step
I'm in Canada. . .I've a friend that is a dealer for Precision but we also go throught a company in the states who is pretty much across the street from Precision. . .I won't promote either of them but if you guys are interested I can see if they could start something up with SAU. . .would have to go through all the proper channels first. . .
Something I picked up a few weeks ago. . .won't become a reality for about another year. . .trying to get my original project finished. . .
twin Precision 4828 billet. . .gt28rs equivalent. . .for the ol' R33. . .
