Lets put it this way; you'll be having a new bottom end quite soon. The engine for testing is waiting on one part before assembly, and that part is being picked up at the end of this week and sent...
Oh getting excited!
My 6262 was on full 21-22psi by 4000rpm and had strong low end urge. Was a 0.82 housing on a stock RB26 and ViPec better than my GT3582R with 0.82 ex housing
What sorta power did you make? Petrol or E85?
Really? Why did 5 if his customers just buy 5 precision turbo's but he tell u not too? Weird
Strange - him and his workmaate Mark have talked me IN to the 5558 now over the 3076R. Said spool and midrange response pre-22psi is so similar on the street, you'll hardly notice at all, but after 23-25psi the 5558 leaves the 3076R far behind. Got my gate yesterday and have sent out pricing requests to the US for the Precision CEA billet 5558 T3 / V-band and 0.63/0.82, surge slotted 3" cover.
I think mine and Kurtis's feel different and are pretty similar setups.... Maybe one day we will run em up on the same dyno and see what the rollers say
what kinda of power will these make on e85?
I feel sorry for you guys now..Ron is going to come in here and not make up his mind.
RON JUST BUY A FARKING TURBO STRAP IT ON AND BOOST!
You honestly are worse then a girl at picking things
Lol
Ron- precision have proven themselves already. Good choice
Hahahahaha!!! I am, dude! But yes its happening this week..
Edited by rondofj
Low mounting on stock mani for that shopping girly look, 0.63a/r as recommended by Jezzabelle n Jase, clicking on 'buy now' soon to shut myself up - these things come with the pretty anti surge slots that dont seem to work on the kandos..but gotta live with that.
This is NO good Ron................ NOAWWWWWWWWWWWWWWWWW :D
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
