Guys....just changed my mind again..not buying a precision... :whistling:
Waits for half of SAU to slap him..... :whistling::whistling:
NAH ! Just put my order through now through paypal. Precision CEA Billet 5558 0.63/T3/V-band plus two silicon joiners $1045 usd delivered to SYD. Wooooott ! ! ! Done! Hurrah.. lol
Were you sweating a little bit as you clicked that button, Ron? :P Lol just jokes mate, looking forward to results, good stuff on finally committing!
I was sweating like a pussy when I clicked that button Hanaldo, and Jase, ur welcome for a ride when done mate, but I'm not a errm..extremely safe/cautious driver..ask err Jez. lol.
lol well making the car even faster is not a good way to become a better driver IMHO.
i generally advise people to thrash the life out of something underpowered to improve their skill. i dont have any advice for you with a 5558 powered NEO :P
All the ones i have done have made big power on 22psi. Havent needed to go bigger boost as of yet
Will be tuning sr20 with 5558 external this week or next. Just running motor in
How did you go with that 5558 on the SR20? Ball bearing or journal? Do you have any further information relevant for SR20? (thanks in advance!)
I just bought a top mount T3 external set-up with 44mm tial gate but minus turbo and am trying to work out what turbo to go for (who isn't :wacko: ).
Currently makes around 270rwk out of a T2 3071 internal gate on 23psi with E85 and Tomei 260 cams, standard bottom end for now (Unigroup dyno) so I obviously want more than that, actually a lot more than that - ie ability to push to 350rwk later on. Unfortunately, it still has to retain reasonable response for a track car (very irregular street car) which makes it a bit trickier.
So far have narrowed it down to;
  • 5558 journal or ball (55 exducer, 58 inducer)
  • 5858 journal or ball (58 exducer, 58 inducer)
  • TD06SL2-20G 8cm (3" inlet, 52.5 exducer, 54.1 inducer - think it might be too small as most results seem to be around the 250-295 mark)
  • TD06SL2-25G 10cm (4" inlet, 60.5 exducer, 54.1 inducer)
It seems the 5558 will make the numbers but on high boost (not good for standard bottom end) and the 5858 will make it easier but will sacrifice some response in doing so (not good for turns 2, 9 at EC and fish hook and last corner at Wakefield ;) ).
Currently leaning towards the 5858 ball bearing but not sure about the response it will give.
jump on NS.com and have a look at DRE20's car, he has a 5858 and the dyno plot makes it look fantastic. very nice and broad powerband. Do this if you really want that 350kw 'down the track' setup.
FYI the TD06SL2 20G is a smaller turbo than what you have now and the TD06SL2 25G (T67) is more of a 6cyl oriented item.
If you simply buy a T3 .63 external gate housing for your current turbo and retune your car will improve everywhere. You should crack closer to 300kw and response will also improve. This is what I recommend you do.
If you want to sell your 3071, please PM me.
Yeah I never thought of that! I just put a brand new rear housing on it a year or so ago. But I think I will sell it.
Yeah I'm on NS and have seen the build. Scale is in speed so hard to tell but the graph does look good. Its also a large bore engine with 90mm pistons.
http://www.nissansilvia.com/forums/index.php?showtopic=516776&st=60&p=6623610&hl=precision%205858&fromsearch=1entry6623610
There's also Joels 5558 BB. Hard to tell what its like with the graph he has put up though.
http://www.nissansilvia.com/forums/index.php?showtopic=521707&st=30
NYTSKY: Is that not what Hi-Octane were running on their R34 at WTAC?
I think it was a 65, could be wrong.
The 32 had a 6262 on it and was absolutely flying. One of the better sounding cars there too.
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
