We are getting ready to do a back to back with a new plenum, the car doesnt exactly look legal at the moment as the rear gaurds are cut ready for widebody so cant do much street driving atm.
Still need to check exh cam gear timing as we havent touched it, is set as the engine builder set it.
Simon, a tip for the fabricator of your dump. Attach the supplies V-Band flange to a turbo before welding it! I had to skim mine as it warped slightly with tig welding. Also simon, pm me your mobile number for some pics of the mount position, i had forgotten about them till just now
Cheers, Allan
Cheers, Allan
I want them too, jerk.
Keen to see results simon, any idea how long it will be untill its all bolted up?
Does anyone have any results from the 6766 or 7175 on an RB26 or RB30DET? would like to know roughly what responce they have, still tossing up between the 6466, 6766 or 7175 . . half of me wants responce, the other half wants power
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
