Depends if he is running E85 or not, my 6262 went 450kw on a hubber running E85 with baby cams. When it was making that power top end it was only running 19psi.
I'm sure on 98 you should go close to 400rwkw on 20-22psi with a 6262
Got a new fuel pump (Magnafuel) that arrived today... Getting it all ready tonight and hopefully back on the dyno tomorrow.
See how it goes on 1.6bar throughout the rev range, hell if I get cheeky might go 2bar and go for 500kw :)
Do it. You won't do it. :P
myengines back in the car, 6266 is bolted on and custom oil/return lines made
just waiting to finish the dump and intercooler pipe then its turn key, wont be atleast afew weeks till its tuned to post results (on e85)
simon R32 keen as to see your results mate, whats the flow difference between the walbro e85 and ur new pump?
Walbro 355L/hr at 70psi and the Magnafuel Protuner 625 402L/hr
Walbro is so much better... Smaller, lighter, quieter and cheaper but can't be used externally so I had to look at other options.
Fired up the Magnafuel tonight, it's pretty loud (would be louder than a pair of 044s) but it should do the business
Did you replace the Walbro due to outright flow or lack of stability in pressure...or other reason ?
I had a Walbro in the Green car, was perfect. The GTR had a surge tank and Bosch 044, it ran out of flow so I needed to go either twin 044's or a big single pump, hense the Magnafuel getting the tick.
Hey guys, Nearly D Day for my GTR to jump on the rollers With the 6766 CEA & e85. Be Interesting to see what Jez can do with the beast Dont think hes tuned something this big as yet Maybe, except for the T88 Top Secret GTR.
I bet Alot of you guys are wondering what the 6766 can do on a Built RB26, Well I havent seen what they can do as yet anyways. shes got big cams in her so will be interesting 280 11.5mm Lift Just hope the engine likes the boost that these turbos produce.
Twin scroll ryan 4inch inlet & 3inch out from memory. Has 3.5 inch exhaust but not that thats going to matter its coming straight out of gate so should sound the goods lol.
What comp ratio is the engine? Any tricky headwork?
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
    • I'd want at least $40K for mine, but thats easy to say cos I'm not selling anyway.
